Blend circuit with independent WET & DRY controls
SYLV9ST9R
I'm looking to build a parallel effect blender with separate WET and DRY controls.
I looked a bit around, but couldn't find a DIY solution, so I thought I asked here for a bit of guidance.
Thanks!
The runoff groove splitter-blend is probably a good starting point, especially because it has the phase inverter switch like the bright onion pedal. (the guitarpcb buff/blend board doesn't without modification). Basically just connect one color of the send & returns, and replace the blend pot with pots for each signal path. Don't quote me on it but I think this would be close
I had come across this schem, will look into it more in details.
Thanks!
