So, I tried the Brass Blender stripboard layout and was rather pleased with the result. I had some troubleshooting to do but was user error. I didn’t cut one of the tracks fully and hooked up one of the pot lugs to the incorrect hole. The wiring is kind of a mess and WAAAY too long, but I will trim it down when I decide to box this up. For those of you interested I hooked this up to my breadboard with the bazz fuss circuit to test the looper and works great.As mentioned before, the phuzz dawg bass blender would be good.
Also check out Charlie “Moosapotamus” Barth’s blender, based on the Brassmaster
Craig Anderton’s looper-blender is good, GPCB calls it the Paralooper; there are vero layouts for it if you snoop the usual places.
GGG has the Parallelizer
JMK’s panner etc is/are good
THCustoms has something o this ilk as does Schalltechnik.
VFE’s 3- channel might be overkill as would EHX’s simillar tri- channel splitter-looper.
That depends. A lot of times with stripboard all the offwiring allows the board to float above the enclosure and I wouldn’t need anything. The alternative is a few layers of electrical tapeThat looks great! What are you using to insulate the board from the enclosure?
I like it for whatever that's worthBeen a while since I’ve worked on this, but had a collaboration with my wife about the enclosure art. I may paint over it and start over, but this is a pretty cool vibe for starters
I like it too, but there are a couple of drips that happened that I may just paint over and re-splatter. It's just acrylic paintI like it for whatever that's worth
