mkstewartesq
Hey, first of all, thank you from the bottom of my heart for taking the time to think about this issue and give me good guidance on where to look next.If you have some raw TS plugs, grab 2.
Engage all loops and jumper their out and in.
Put one TS in the input of the switcher.
Measure the resistance between each tip.
Then move the output plug to each out jack on the looper and remeasure.
Then move the TS jack to looper out and measure across the looper out and each loops input(return).
If you have a specific part of the loopers circuit that is resistive, this should make it apparent.
Alternatively but not as thorough, just ohm the looper master in and out and engage one loop at a time.
If you find one loop to be an issue, then perform the above on that loop to determine if it's on the send or receive side of that loop.
This is probably a better use of time. Thinking it out as I type...
If you don't have plugs handy, can pop the cover and clip onto the tip connections.
Wouldn't hurt to check capacitance, if your meter has good enough specs to measure that low. I doubt you'll have any in the looper itself but maybe in a cable?
Would be more concerned with your longer cable runs in that regard.
Would be interested in your total system capacitance, end to end.
I started with the second half of your message (checking the resistance at the master input in output as I activated each loop I put a spare TS in each of the master input in output and then jumpered each loop). Activating the loops one by one, the readings always jumped around wildly at first but all eventually settle down to somewhere in the neighborhood of 1.5 ohms measured from the tip of the master input to the tip of the master output. Assuming I followed your instructions correctly, I don’t know if that reading is a good or bad thing. But at least it’s consistent across all of the loops.
Again, thank you, sincerely.
Mike
