mkstewartesq
So I posted in the build forum yesterday about a seven loop switcher I built. At the end of the day, it’s basically seven true bypass 3PDTs daisychained together.
After comparing the sound of each pedal when connected to the new switcher to the sound when connected to my main switcher, all pedals are noticeably quieter on the new switcher. For example, my Boteh/Paisley drive is still distorted to some extent, but it’s not nearly as loud or lively.
Of course, my first thought was a buffer might be needed. But I know almost nothing about buffers. The standard test that I am finding for determining whether a buffer is needed when you have a lot of daisychained true bypass is to test your signal straight to the amp versus through the daisychain with all of the true bypass effects OFF (in bypass). If you hear a tone difference, a buffer is needed. When I try this test with all of the loops on my new switcher in bypass, the difference is either nonexistent or almost imperceptible. So, in an ordinary world, I would think that that means a buffer would not address the quiet pedals issue.
But, again, when you actually activate a pedal on the new switcher, it is a bit weak. Notwithstanding that all of the loops in bypass don’t seem to create a tone suck, is it still a situation for a buffer if the pedals, when activated (not in bypass), are more attenuated then when they are run off of the switcher?
If a buffer does address this kind of issue, is the issue at the input or output (i.e., should the buffer go at the input or the output (or both))? I’m actually going to build a JFET buffer today to give this a shot and try it on both the input and output to see what it does, but since this question goes more to “what problems does a buffer fix and what problems does it not fix?” I’d appreciate any input just for general edification purposes since, again, I’m completely new to buffers.
Thanks,
Mike
Thanks,
Mike
