Pauleo1214
I am a bit confused with this one. I installed all the components and socketed the IC chips and the L78L33 to prevent burning them out. I fired it up and it worked just fine. Something occurred after I installed it in the enclosure. It works in bypass and I get a dry signal when the effect is on; the volume and mix signals work but there is no wet signal generation. Does anybody have a clue as to what might cause this? Are the voltages going to the EEPROM or FV-1 off?
