iamjackslackof
Hi all,
I built a Greatly Improved JFET Matcher II recently, to test JFETs for an Aion EP-3 preamp. Since then I did some reading here how some JFET matchers, possibly the Rullywow one, only measure Vp a certain way, or incompletely, or something... It's all still a bit over my head. If I want to measure JFETs both for something like an EP-3, which requires specific Vgs(off) and Idss values, as well as match JFETs for stuff like phasers, is the Vero one sufficient? I did order a PCB for the Rullywow, is it sufficient? Do I need to spring for a DCA75 to cover all my bases? I have the DCA55, but it only identifies JFETs. I want to have some way of handling all the common JFET measuring situations, ideally in 1 circuit, but 2+ is fine as long as I know each of their uses and shortcomings.
Thanks!
Edit: Related question: The Vero matcher I built works, but I'm not certain which switch position is Idss and which is Vp. Any hints?
Edit2: There's also the ROG version as well (fig. 10), how would it fare?
Thanks!
