Built another Kliche Output is Insane
piapium
I built another kliche. Can't turn the volume up even to 9 o'clock. It has massive output. Don't know why?
My BYOC silver pony works similar to this. In order to turn output past 9 without crazy volume you have to turn gain down. Could still be something not right but the klon does have a ton of output with the charge pump
This is the 5. Kliche I’ve built so far. Never had this issue. Could it be germanium diodes? I also used tl072cp and tl072ip together. I thought it could be the reason. I don’t know. I checked everything looks fine. Maybe I should replace charge pump.
I mean if the diodes are bad it could increase the output like a silicon or led would. All i know is GE has a lower output so that’s a possibility. The suffixes after TL072 Im not sure what they mean. Try looking at the data sheet. I’m not too much help here hopefully someone else chimes in. You should post pictures though.
