falco_femoralis
Hi all, I just put together this Byzantium Flanger, but I'm having a problem. When I turn it on, I get the LED, but no effect at all. There's no boost in volume or any flanging effect. None of the knobs do anything to change the sound, same with the 3 trim pots on the back. I've tried reflowing my solder joints and double checking the values of the transistors. My chips are all legit Texas Instruments, and the BBD's are cool audio. I've attached some pics.
I had an issue with one of the solder pads for C103, so I tied in its leg to the rate control
I mounted some of the components on the back of this board, but kept their orientation in mind
Where should I start?
