Twinningses
Hi Folks,
Newish builder here and encountering an issue I haven't come across before: I've built the Byzantium Flanger but there's no effect.
Pedal bypass is working fine. When engaged, LED lights up, I get sound, but it's the exact same sound as when the effect is off. The knobs don't alter the sound at all, the trim pots don't alter the sound at all, etc.
I read another thread where people encountered this issue from using the wrong ICs and transistors, but I'm using all the ones to spec.
Interestingly, I don't even here any noise from the ICs that I would expect. Absolutely zero affected signal.
And... forgive my lack of low-profile caps here. I didn't have them for this build and so used what I had and just bent the caps so they still fit between the boards. I've been fairly meticulous to make sure their legs aren't touching things they shouldn't be, so I don't think that's what's causing my issue.
Any and all help very much appreciated.
