TheGuy1437
Hello, I finally got back to trying to set up my caesar.
The state it's in right now is: Fully working LEDs, the signal passes normally when the pedal is disengaged. When engaged the chorus effect is barely noticeable even with the blend turned to full and the other knobs seem to have no effect except for the rate which controls the LED. The trim is set to give around 5.5VREF. I've checked the signal path with a probe and I'm getting the signal in all the spots marked with red in the diagram.
What's the next step? Should I try to check voltages and continuity?
