PunchySunshine
New pedal builder here. Finishing up my fourth pedal, I've finally hit a problem and my luck has run out. I made the Cataclysm Delay and everything functions properly except there is a steady 2Khz noise happening. It's only when the pedal is on. It doesn't matter if it's inside or outside the box. I've tried powering with a 9v battery and it's still there. I've swapped out the tl072 opamp. The PT chip is getting 5.2 volts on the first pin and 2.6 volts on the second pin. I've run out of ideas on my own and I'm hoping you wonderful ppl can take a look at these pics and we'll get it sorted out.
Thank you in advance!
