BipolarBear
Whats up all,
Just built the CDXL Reissue envelope filter, but when it's all together I'm getting almost no signal at all (without any effects either.) LED and true bypass are working as intended. Could this potentially be an issue with the LM358? I messed up the tayda order and got the SO-8 package, so I had to use the DIP8 adapter PCB which I wasn't sure of the orientation for. If the LM358 was put in backwards, would the signal be present but massively attenuated like I'm seeing? Or could there be some other issue with my circuit?
