falco_femoralis
Hi all, I just put together a Ceasar Chorus. I get bypass fine, but when I turn on the pedal, the rate LED is steady and there is no chorusing at all. The preamp is working, and it sounds good, but none of the knobs do anything, nor does the switch. I'm using NOS MN3102/3207 chips from Small Bear. I normally use the cool audio chips but I wanted to try these out. I have the chips socketed and the effect is the same with them removed. I don't have another set on hand to try.
The pedal setup is kinda weird so I had to take it apart to troubleshoot, and I don't have functional pics. I'll have to remake it to be able to troubleshoot. I'm just looking for a ballpark place to start based on the lack of chorusing.
Actually, the blend knob does change sound when turned all the way CCW or CW. It's like it removes the preamp EQ when turned all the way.
Any help is appreciated
