DailyDovetails
- Build Rating
- 5.00 star(s)
Here is a 6 knob Chalumeau I built. The extra 1k pot is a gain control going from pin 1 on the lm386 to pin 8. I like the added range the gain knob adds. I have gotten some decent sounds out of this I like it turned low with the gain down a bit on cleans. I makes some big sounding lead lines into dirt. A lot of the settings are too wacky for me to use. I think I need to play with it a bit more.
I’m learning Inkscape and used it to make the design on the pedal. It’s a spiral made out of different length dashes.
I learned the LDR coupler on this leaks light in dark grey I will likely do them only in black moving forward.
This was an easy build it worked first try.
