y-u-no-f800b
I'm gonna build an 18v rat using the Muriodea board and the 3pdt charge pump board. Since there's no build doc for the latter, I could use some help. First, are there redundant components between the two boards? Like, does the charge pump board have a polarity protection diode, and does that mean I should omit the one on the Muriodea pcb? Is this the case with any capacitors?
I've already got the board on my desk. I'm also not sure what to make of the multiple in/out and +/- holes. I was able to find in another forum post that the board is meant to take a mini spst switch on the right (something i didn't know about without a bom) or can be run at a fixed voltage at the bottom right. I'll just stick with the fixed 18v. Since that's the case, are there any parts on the charge pump board that i should omit, besides the spst, or are they all necessary?
I've had a great time building the Antithesis, Squidward, and others so for. Hoping to keep the streak of good builds going!
P.S. All my caps are 25v or higher. Thanks!
