Chop Shop Calibration 12/15/22
abelovesfun
Built a chop shop. It passes signal and all controls seem to work. I just am unsure on calibration as the documentation has nothing there: https://docs.pedalpcb.com/project/ChopShop-PedalPCB.pdf
Right now I have all pots at 100% but my max DC measurements on the test points is 2.5V. Should all pots be at 100%. I used a 2n2222a so I put it backwards, and the J201s are from a trusted batch that I use to make triangle > sine shapers all day.
Sometimes it’s best to tune your FETs by ear rather than a specific voltage. Adjust the first trim pot until it sounds best to you, then do the second one. Then go back to the first one and fine tune it. Everything should “snap” into place
