Alan W
- Build Rating
- 5.00 star(s)
My plan was not to post build reports until I had a "finished" pedal to document, but I just can't let my delight in this simple design stay contained. Granted, it's a very honeymoonish fling, since I just finished the wiring yesterday. So—first a brief review, then I'll give a build report.
I had high expectations for this, after having owned a few Fairfield Circuitry pedals. They are all very distinct from the mass of circuit borrowed merchandise out there—designed with a fairly specific goal in mind, I think. This is a lowish gain drive pedal, with no tone controls, and the gimmick of having a sag control to under-supply the transistors. I don't get along with most drive pedals. I like a good, very clean gain stage, and the Transcendence Boost has made me very, very happy. (Holy Fire stayed on my board for 15 or more years, 48V wall wart and all, so the fact that the Trans. largely has the same sound as the HF made me happy—but I sort of expected this.) Even as a clean only drive (ie, no Sag or Drive added) the Chopshop sounds great—not truly clean, but clean enough, and with a fairly neutral, but slightly weakened bass and lower midrange. (So far have only played single coils into it, and only into a brown/black Fender style amp.) The breakup is entirely natural, in ways that a diode breakup just isn't.
Adding in a small amount of Drive brings the lower bass and midrange back to balance. Adding more drive doesn't smear distortion over everything. It still REALLY follows your playing dynamics. Much to my surprise, I spend quite a while last night with the Drive dimed! The Sag also works in a pretty natural sounding way. The amp I played with (and still own) until the "clean Fender" bug bit me a few years ago, a Top Hat Club Royale, has a switchable rectifier in it, with hard and soft settings—the sag in an exaggerated version of that (but can be used subtly).
Basically, what amazes (yes, not too strong a word about this pedal) me is that everywhere I had the knobs, it sounded great. I don't think I've ever run across this before. My Baritone Tele is a good testbed, especially for lower frequencies. If this pedal had tone controls, I'd just leave them as close to being out of the circuit as possible. I'm going to play P-90s through it later today; I've got pretty good sense of how sensational that weill sound.
Until final assembly, the build went easy. I've learned that I need to double check all my soldering, parts placement, etc. I do this all along the way. When I plugged the pedal in, I got no sound. Well, if I cranked drive and volume up all the way, I got greatly attenuated sound. I could still tell that the sag was working too—but all at a good 60 or 70 db below what it should be. This made me suspect the 2N2222A I had used. It tested fine, but I had been confused about pin-outs, having misread a post that included bias instructions, thinking that the 2222 and 2222A had reversed pinouts (it was the P version of each that is reversed...) so I began second guessing that, because since everything seemed to be working, I thought that final output was being strangled there. But, even after replacement, and more checking with my 75A tester, it was a no go. Leaving having to pull the board as a final option, I got out my 8X binocular loupe, and a bright lamp, and just looked at everything. There is was, a cold solder joint on the stomp switch, at the output. (This made me think about how I check and recheck everything so carefully, but generally just solder the stomp in and trim it, no further inspection.) In any case, that was the issue, and a quick reflow took care of it. Oh—IDSS for Q1 was 720uA and 540uA for Q2, and I was able to dial in 6.00V on the drains easily. First time using a Gorva stomp, which I think will replace the Alphas I've been using.
Here's a front and gut shot, along with my current plan for the painted design. Just non metallic glossy white and red, with black lettering. I'm holding off on doing painting until I have designs for about 10 or 12 pedals finished, and will then order the transfer lettering I like to use. (It's too expensive unless I gang up a bunch of pedals.) I may not include the dots around the knobs...
QUESTION ABOUT VOLTAGE: Fairfield says 9 or 12 volts. At least one person on TGP that I have come to respect says he runs his at 18V—and I want to try this; nothing I used has less than a 35V rating, so while I don't see any potential problems, I'm also just a bit leery. Does anyone here have experience with running this at 18V? (And, when biasing for 9 volts, I checked at 12V, and the bias drifted to just below 8V—if I can run this at 18V, should I leave bias where it is (set while at 9V, or should I set it to 12.00V? (I'm expecting it to be close enough to 12, but I love nice round numbers.)
