benevolent-fur
Hi all,
looks like I'm destined to never get one of these pedals right the first time! I thought I'd just finished the Chop Shop v2, but am having the following issues when trying to use it:
1. The drive knob appears to not be doing anything - there is grit, but no variance when the knob is turned
2. The sag knob has lots of grit and max volume when turned fully CCW, but from about 4 o'clock onwards when turning it CW the volume decreases so much that it's basically gone. There is still a signal when I look on the DAW but it's not audible.
Thankfully the volume knob functions properly.
I've tried to bias the pedal to the best of my limited knowledge, but am unsure if that could also be an issue.
I've tried running the pedal at both 9V and 18V and there is no change.
I've tried both single coils and humbuckers in case the issue was the strength of the pickups.
Any ideas what I've stuffed up here based on the attached picture?
Cheers
Cheers
