Many__Of__Horror
Interested on your thoughts on if it is necessary to ground the circuit input when in bypass. I am looking to wire up a common anode bicolour LED & would need lug 6 to connect to the 2nd cathode leg.
I have only ever used the below wiring method, except for one time on an Angry Andy Plus build which used both sides with a bicolor LED. The boost side gives a pop the first time you use it then goes away. Wondering if it caused by not grounding the circuit input when bypassed?
