Synchrony Pedalworks
I have a 125b enclosure that looks great. My plan was to use it for a Paragon mini, but I drilled the holes in the wrong places. I ended up using another enclosure for the Paragon mini, but I'd like to try to use this enclosure. Unfortunately, I am not seeing many circuits that utilize that many pots and footswitches. It has space for 6 pots and 2 footswitches. Do you all have any suggestions? Ideally, using one board would be best, but I am will to try a combo build in this tight space. Because the holes are not aligned with a typical PedalPCBs template, I will have to do a lot of off-board wiring...ugh...
Thanks for the suggestions!
Andrew
Andrew
