p_wats
Anyone ever notice the clock module sort of locking up? For example, I'm trying to add it to an FV-1 build now (having already removed the crystal and 15pf cap from the main board) and it seems to be working well enough, but exhibits the following behaviour:
Otherwise I'm experimenting with a resistor between lug 3 and the board, so there's always some resistance there, but was curious if anyone else has seen similar behaviour or if maybe I'm missing something.
			- If the 10k control is dimed (0 resistance between lugs 2 & 3) when power is connected to the board the effect doesn't seem to start (no wet signal)
- If I back off the control then re-connect power it all works fine
