Hi,
I got the 3PDT LED v2 board from LMS but I'm not clear on connecting it to the Taqueria board.
The Taqueria PCB has "In Gnd SW Out" at the bottom.
The LMS board has:
J = Input Jack Tip
I = Circuit In
V+ = Positive Voltage - there's 2!
G = Ground
O = Circuit Output
OJ = Output Jack Tip
GND = Ground
I guess the only one I don't see is SW. I was thinking of using a ribbon cable for a quick connection but the pads don't seem to match up with theTaqueria board.. This is my first pedal build so I'm new to this & probably missing the obvious. If SW is used for an LED, I think I can use the other contacts on the LMS board for the LED. Does anybody know what the correct pad is for me to connect SW to?
Thanks
The LMS board has:
J = Input Jack Tip
I = Circuit In
G = Ground
O = Circuit Output
GND = Ground
Thanks
