Copper Clad Fuzz/Mythos Golden Fleece in a 1590a
OD is Glorious
5.00 star(s)
This Fuzz sounds wonderful and it worked on my PedalPCB Auditorium Platform.. My second time putting a PedalPCB board inside of a 1590a. It fit easy if you know how to position components and tilt the pot and board. I love the pedal and I am happy with how it turned out. I previously put an Enchanted Boost in a 1590a, and I learned some lessons that helped me with this project. You will see some photos of the process and I had to file the lip of the case cover. All in all, a fun project.
It has a blue LED, a low profile footswitch, a powder coated Tayda 1590a, lumberg jacks and D.C., an anodized aluminum knob and I used a breakout board. The low profile footswitch does not quite fit the BO board so I bent the solder lugs. IMG_9920.jpeg IMG_9922.jpeg
What a tight fit! I enjoyed seeing the process documented in photos of getting it all in there :) Thanks for sharing! I don't think I'll ever have the patience for a 1590A build. 🤣
How does this fuzz compare to others that you've tried/built?
Thanks. I am usually not a fan of fuzz but of the few I have played or built, my favorites were the Sandspur and this one. Probably a tie. This one has no flub so it feels tighter. It has some power but not overpowered. It does require a D9E and I have not tried other diodes. I sourced this one from PedalPCB.
