I’ve been enjoying following this thread and admiring your clean vero work.
For the bass, one thing you could try is increasing the value of the bass pot. 10k may not be enough to completely take it away with the knob at minimum, though I’m not sure if that’s your problem.
Yes reducing the 220n like you mentioned would reduce some low-mid content. The 1k and 220n determine the cutoff frequency of the high pass filter (F=1/(2piRC) = 723Hz). So reducing the cap would raise this frequency. Reducing the 1k also has the same impact on frequency, although it also adjusts the gain range. For the cap, I’d probably start with 150n (1000Hz) and Experiment from there. You could also try a trimmer where the 1k goes to help you dial in the cutoff frequency exactly (like how the voice knob works on a zendrive).
One more thought based on your description, maybe your happy with the cutoff at 723Hz, you just want a steeper roll off. (It’s currently a 1 pole high pass which can have a shallow effect). I think by reducing the 22n on the input, you could have 2 separate HPF around 723Hz. Using the 470k to Vr as the “R” for the calculation, I get that 470p would put that filter at 720Hz (Not sure if that’s close Enough, do I need to consider the impedance of the op amp for the calculation, chuck?). The problem with this method is it permanently removes some bass. So with the bass knob down you’d get 2 pole HPF, with the bass knob up you’d have 1 pole high pass. (Please correct me if I’m thinking of it wrong). Of course you could also put those caps on a switch to have all the options.
reduicing 1uF at pin 6 could also work. I just thought since there is some soft clipping in the op amp feedback loop, maybe you’d want to cut bass before that.
