SOLVED Cross Contaminator
Rock'n me
Hello,
I just finished the cross contaminator. But he doesn't make a sound. I suspect, I installed the transistors incorrectly, because unfortunately the imprint on the circuit board does not match the design.
Basically, it would be very nice if the pinouts were listed on the boards, especially since the intended transistors are often no longer available.
Does anyone know how to mount the 2N1711s?
Greetinggs from Germany
R.
Post some nice clear images so we can check values and trace your wiring
Easy enough to miss something after checking a few times
Do you get bypassed signal
