Reinholder
Hi all, recently finished the dark rift delay and am noticing a overlay of white noise/fizz on top of the repeats. I've searched through the forum and found a suggestion to add a green led between the 7th pin and 3rd pin of the PT2399 may potentially calm the noise a little. I gave that a try and it didn't seem to help with the noise (it did reduce the volume of the initial repeat slightly and I can see the led light occasionally when picking hard).
I've also read a bit about PT2399's and seems like a bit of noise is to be expected when used in delay effects but was just wondering if the noise I'm experiencing here is just standard PT2399 things or not.
Wondering if anyone has the real version of the pedal this one is based on, and if so, is the white noise a feature?
Thanks
Thanks
