zedfyrom
Hi all, as title say I have trouble with a Dark Rift pcb.
The pedal it's working but it's giving just a single repeat. Well actually it's not just a single repeat but the feedback is pratically inaudible except for the first, still low, repetition. I can even tell the modulating it's working but by now this thing it is a useless pedal. I really don't know what the issue can be. I already tried to substitute the chips.
3 things to note in the photo:
I swapped the lm324 with a tl074 to see if i can get any change, but nothing.
D2 it's in reverse to what the pcb tell. I reversed it to try to align to what the build guide says but that still not was the fault.
In the place of R7 there are 2 resistor in parallel that i tested to be 8K (required value is 8.2k, but i don't think that's the problem again)
Please note that the mix and the feedback pots are maxed out in this audio sample.
And here are my voltage:
Pt2399
Pin1: 4.5
Pin2: 2.25
Pin3: 0
Pin4: 0
Pin5: 2.63
Pin6: 2.25
Pin7: fluctuating (average 0.32)
Pin8: fluctating 0.65 to 0.66
Pin9: 2.25
Pin10: 2.25
Pin11: 2.25
Pin 12: 2.25
Pin 13: fluctuating 0.01 to 0.02
Pin 14: 4.5
Pin 15: 2.25
Pin16: 2.25
Tl074:
Pin1: 4
Pin2: 4
Pin3: 2.2 then start to drop
Pin4: 0
Pin5: 3.93
Pin6: 4.02
Pin7: 4.02
Pin8: 8.05
lm833:
Pin1: 2.26
Pin2: 2.26
Pin3: 2.20
Pin4: 0
Pin5: 2.22
Pin6: 2.25
Pin7: 2.26
Pin8: 8.05
lm324:
Pin1: oscillating from 2.5 to 5.something
Pin2: 4
Pin3: 3.92
Pin4: 8.05
Pin5: oscillating like pin 1
Pin6: 3.6
Pin7: oscillating from 1.something to almost 7
Pin8: almostl ike pin7
Pin9: like pin 1
Pin10: like pin 1
Pin11: 0
Pin 12: 3.9
Pin 13: oscillating fom 3.8 to 4.2
Pin 14: oscillating from 1.6 to 6
Pt2399
Pin1: 4.5
Pin2: 2.25
Pin3: 0
Pin4: 0
Pin5: 2.63
Pin6: 2.25
Pin9: 2.25
Pin10: 2.25
Pin11: 2.25
Pin 12: 2.25
Pin 14: 4.5
Pin 15: 2.25
Pin16: 2.25
Tl074:
Pin1: 4
Pin2: 4
Pin4: 0
Pin5: 3.93
Pin6: 4.02
Pin7: 4.02
Pin8: 8.05
lm833:
Pin1: 2.26
Pin2: 2.26
Pin3: 2.20
Pin4: 0
Pin5: 2.22
Pin6: 2.25
Pin7: 2.26
Pin8: 8.05
lm324:
Pin2: 4
Pin3: 3.92
Pin4: 8.05
Pin6: 3.6
Pin9: like pin 1
Pin10: like pin 1
Pin11: 0
Pin 12: 3.9
