Finished assembling the Daydream pedal. Four of the five controls perform as expected. The Width control seems to work a little contrary to what I expected and/or understood its function to be.
First, the repeats get very peaking (thin and higher frequencies). With the Width turned fully counter clockwise, the tone is warm but the effect is limited. As the Width is turned clockwise, the effect increases with the repeating pitch ascending and getting peakier as more of the effect is applied.
My understanding was with the Width at 12 O'clock, the repeats would ascend or descend based on which direction the control is rotated. Is this not correct? And while I know the term peaky is subjective, the tone of the repeats get thin (upper frequencies) and almost sounds like an mild envelope filter.
I placed a On/Off/On toggle on the board and the two On settings provide two different effects while the Off position appears to simply bypass the effect circuit entirely. I assume this function is correct.
Anyway, I know it is a challenge to diagnose or determine if this is functioning as expected based on no audio and subjective description, but if anyone had assembled this build and has some insight to share I would be appreciative.
Thanks guys/gals.
Thanks guys/gals.
