PoppaAdat
I just stripped a Parentheses Fuzz PCB that was my first ever DIY pedal project. I had gotten about halfway through a very shoddy job of it before realizing I didn't have all the parts (and probably using some parts of questionable quality) so I put it aside. Now after a few successful pedals and being much better as soldering, I decided to strip it and start over. My question is in stripping it, I seem to have slightly removed the black covering in a few areas as well as burned a few areas around the pin holes. Will any of that be a problem? I was concerned about the metal underneath the black layer coming into contact with a solder joint and potentially sending that area to ground.
For the burned hole areas, I am assuming I can take a fine file to that area and try to get down to unburnt metal if it matters.
I tried to point out the areas I am referring to in the second pic. That pic especially show where I scraped away too much down to the metal underneath.
I already cleaned off both sides with isopropyl alcohol.
Any help is greatly appreciated!
