Deflector problem
Audioguru67
Hi!
I've finished my Deflector, I've tested it out of the box and it worked great, I've put it into my enclosure and the "Deflector" knob has stop working, I've check the continuity and it seems ok, anybody got a problem like that?
Pascal
You may be shorting one of the pot leads to the enclosure. If its still in the enclosure, check lead resistance to ground. Only lead 1 should be grounded, lead 2 will vary depending on where the pot is rotated to and pin 3 should be around 50K. A couple of pieces of electrical tape on the inside of the enclosure under the hole for the pot should fix this.
