Disarray Distortion
faramir
My first ever build! Everything went pretty smooth. I did use 1N4148's instead of the 51E diodes but everything else is pretty much as specified in the build doc.
I used Tayda's UV service for the enclosure. I designed the text in Affinity designer. It took a bit to get the hang of, but not too bad will probably try more than just plain text in the future. The case is metallic candy purple and the knobs are clear to channel the Riot Reloaded energy.
Sounds awesome. Definitely alot of gain. It does squeal a bit with the volume and gain all the way up so maybe I screwed something up but other than that it seems like its doing what it's supposed to. The voice switch is more subtle that I was expecting.
Thanks for making this so easy to do!
