Cybercow
UPDATE: The schematic is now corrected & updated.
A few years back Dimitris Smith Diamantidis created a neat little BBD test circuit board. It was available thru DSMCZ. But since, Dimitris has pretty much moved on and DSMCZ is out of stock on those PCBs. I had been in contact with Dimitris in working up a more comprehensive BBD test circuit to incorporate also testing the MN3011, but he just dropped off. His PCB was simple yet quite workable, allowing several of the 8-pin BBDs (MN3007, MN3207, MN3101, MN3102 & a few others) and the MN3005/MN3205 to be tested.
I was able to trace his original PCB and added a bit to the schematic for testing the MN3011. His original PCB looked like this:
The 4 pin holes above the 8-pin BBD footprint is designated for installing jumper pins for changing between the two primary clock chips used with BBDs - the MN3101 & MN3102. By changing the jumpers from parallel vertical to parallel horizontal, one could easily test the MN30xx or MN32xx series devices.
So without being to reach Dimitris any longer, I've made some changes to the schematic but not being at all proficient in PCB design, I am stuck at this point in progress to re-vamping the PCB to include the MN3011 chip.
Here is what I have written up so far. (It just needs a PCB layout.):
I have verified the MN3011 addition with the help of a little test jig to augment the original BBD tester . . . .
Any comments, suggestions and/or other ideas are welcome.
