mkstewartesq
OK, so I’ve already devoted enough space in other threads to my “7 loop switcher” build and whether it needs a buffer. I’ve decided it does and I actually built a Cornish buffer on stripboard that I like. However, because I’m going to have some treble boosters on that board (which the buffer does not play nicely with) I’d like to be able to turn the buffer on and off. That would be simple enough. But wait, there’s more.
1. I found that it sounds slightly different when used as an input buffer versus an output buffer so I’d like the option to make the Cornish buffer go into the signal path in the looper either as an input buffer or as an output buffer (with an option to take it out of the signal path entirely). This means setting up some way for it to either enter the signal chain between the input jack and the input of the first loop or between the output of the last loop and the output jack. I’ve wasted most of a pad of paper trying to figure out how to wire this up on a DPDT (I assume it would be an on-on-on) and apparently I was smart enough to make it through law school but not smart enough to figure out how to arrange wires on six lugs to achieve the result I want. Or it may very well be that this is simply not possible with a DPDT.
I’ve included a diagram below. Does anyone have any suggestions how to wire this up – or to confirm that it’s simply not possible with a DPDT?
2. Fallback plan – if there is a way to wire it so that it can be an input buffer or output buffer but lose the option to take it out of the signal path entirely, can anyone give advice on how to do that as a fallback plan (again, if even possible)?
Thanks, as always,
Mike
Thanks, as always,
Mike
