Paradox916
Not a flawless victory by any means but wanted to give one of these a go. Off board wiring so clean it doesn’t exist! no visible scratches on a ball silver enclosure, white washers you say? It has them! They worked good for truing up the switches and leveling the board. There is definitely a preferred method of assembly... mount the jacks and switch’s in the enclosure then solder on final assembly.. did I screw up? You betcha! But not on assembly. It might just a mater of point of view but from the perspective of send/ return the arrows are backwards on the loops, DOH! Well they can’t all be winners... but it did turn out pretty clean so I guess there’s that.
