Hello everyone, I've been trying to finish up this 2 in 1 pedal with a footswitch to toggle between true bypass and the effects and a toggle switch to swap between a "clean channel" fumble boost and a "dirty channel" m800 overdrive. I installed the fumble boost first and was able to get it working with the true bypass toggle. However, after I added the m800, I am only able to get sound during true bypass and no longer get sound in the clean or dirty channel. I was wondering if this is the proper wiring as I assumed I just had to switch the input and output from the effects to the master switch? Otherwise I can start tracing down a short somewhere.
I'm also only able to get down to 5.3V for Q2 but every other trim pot seems fine. I don't know if this is an indication of a wrong component or if this just occurs with tolerances?
Thanks for the help in advance!
