I'm building the Duo-Phase and I had a question about R38A, R38B, R46A and R46B. Since the Duo-Phase is two identical phases I'm assuming the circuit is the same on both sides. On each side the layout is identical except for R38A/R46A and R38B/R46B. I understand that the layout is not indicative of the circuit but since everything else in the layout is 100 percent the same I thought I'd see if someone could verify. Thanks in advance!
