chongmagic Well-known member Feb 16, 2019 #1 Can I use a 2k instead of a 1k. I don't have any 1k on hand.
jjjimi84 Well-known member Feb 16, 2019 #3 Yes to the trimmer and yes to the transistor, though i would socket it in case of any noise you may get. You should be fine but socket it just in case
chongmagic Well-known member Feb 16, 2019 #4 I think I messed up the anode pad for diode D1A should I run a jumper to the TL074?
chongmagic Well-known member Feb 16, 2019 #5 Looks like I screwed the build, D1A connects to pin 8 of three different LT1072s. Ugh.
