SOLVED Duo phase wiring, rate and switches
Grazza
I have just finished a duo phase, picture attached. The rate seems pretty fast, maybe slightly faster on one side than the other. Do the trimpots affect this? Or is there a mod that can be done to get a bit more range in the rate?
It's wired stereo at the moment and seems to be just two separate pedals period, only work if you plug into all jacks, for some reason I thought that if you plugged into one side you get to use both still? Or should I just rewire it in mono.
Also the switches don't seem to do anything, is this due to the way I have wired it?
I think this is beyond me, i cant seem to get it working. The layout diagram shows one switched jack on the right hand side, ive tried the both of the mystery lugs and the effect functions but only the side that is plugged into still.
I believe I have figured it out, I have been trialling all the lugs and different jacks etc with alligator clips to save heaps of soldering. If I have the switching jack in the circuit and I plug into the input on the right and the output on the far left, which is the other sides output, the effect works as it should. Both sides work, and both at the same time and both switches do something. I think it works! You help has been so greatly appreciated, it is special to have such a great community of knowledgeable people like yourself who are willing to help and share their wisdom. Thankyou
That’s great! Are you gonna make a build report? Also you can mark this thread as solved. Good luck with your next projects, we are always here to help!
Thanks for that data sheet, awesome. I have never done a build report, didn't think my skills were up to showing off, maybe I should for this one so dumbass' like me can see what a switched jack is. Thanks again for your help. The pedal actually sounds really good too, especially when both are going at once.
