EHX OD Glove trace?
Magous
Does anyone have the schematic for the ehx glove? It’s a clone of the OCD, but there is a noticeable sound difference between the two. I’m not sure which version of the OCD the glove is a clone of, but I’m hoping someone has the schematic so I can build it with the ADHD board. A lot of the difference sounds like a change in presence between the two, so I doubt there is a major difference in any components. Anyone have it? Or know which version of the OCD is a clone of?
Appreciate you.
I don't have the schematic, but you could compare the vero layouts for component differences:
As far as I know it is supposed to be a OCD v2 clone but my diy ocd sounds different from it slightly, even in its v2 mode. The glove has, as you mentioned, slightly less presence at the same setting but it is very very slight.
I would say exact same schematic but couple of values could be different. Sounds like the high pass has either a different frequency or slope. I haven’t looked in details and both pedals were on my board only a short time. Kinda situation were you initially think « l don’t need both they do the same thing » then get rid of one and realize there is that thing missing.
Slight as in Component Tolerance Drift or more pronounced than that?
More pronounced. The schematic for the glove up top and the ocd have several differences. There’s so many different ocds though that it’s hard to know which it’s a clone of. I’ve had two gloves and they sounded indentical, and had a v2 ocd and it sounded different than them. I definitely prefer the glove, but for all I know it’s an exact clone of an earlier version I haven’t played
It just sounds different, other than just presence also, but I can’t describe it in words. Crisp? Idk
Slightly OT, am I the only one who think the better sounding resistence in the output filter (the one with the switch) isn't 33K neither 22K/33K paralleled but a plain 22K ? I discovered it by chance inverting the two resitances for an error
Meaning a 22k where the 33k should be, and the og 22k left out or jumpered?
