My first build is an El Sol and I'm not getting any sound when the pedal is engaged. The DIYPedals subreddit gave me some pointers, but no luck.
I accidentally bought 10mm 10u caps instead of 5mm, and a B100k pot instead of an A100k, but I don't know if that will stop it from functioning.
The pedal works in bypass, no sound when turned on.
Unplugged from the guitar and amp the LED works. The LED turns off when I plug the amp cable into either jack.
I tested the ICs with a multimeter and they seem fine.
I re-soldered the pot after the picture was taken.
Tried flipping the LED around.
Any pointers would be appreciated. Thank you.
