jhalton
Not sure if this is an okay forum for this, as its technically not DIY?
So, this pedal served me for many years, then stopped working (around 2004). I paid a guy to repair it, and long story short he made everything worse. I threw it in a box.
Fast forward 20 years, and I have been successfully building diy pedals for a year now. I figure I may have the skills to get this working again (possibly), but need help. I am not electronics knowledgeable (I just put components into PCB's!).
I am hoping someone out there has the time and will to give my some direction? I will add some photos below. I've already done some work, but I need to do off-board wiring now, especially the power section. The 24v doesn't seem recoverable to me, plus I'd like a more user-friendly power option if it all possible. Anyways, thoughts are welcome.
The main thing I'd like to do is the power mod like shown at this blog: https://sites.google.com/site/david...leeffects/electro-harmonix-memory-man/ec-2000
I also did a post at r/diypedals (https://www.reddit.com/r/diypedals/s/Ua2ef19laI), so I will copy what I wrote there:
To sum up, I need a new power option. The big transformer you see in the second picture is not recoverable. I want to change it to use a typical 2.5mm coax connector. I know this is possible, as I found a reference to it being done (David Morrin - EC 2000 Deluxe Memory Man Reissue). I will also probably swap the switch to a 3pdt (maybe).
So, i just need to know which wires on the PCB go to where, specifically the 4 on the top left of the PCB. The rest either go to the footswitch, the chorus/vib switch, and the jacks. From what I can see on the blog i referenced above, he removed one diode (D2), added another and another resistor. Not sure what is going on there.
I think I can figure out the rest of the wiring , but the power issue is out of my knowledge level. Hopefully this makes more sense, not sure how else to explain it!
