Electrovibe drilling slightly off for faceplate- suggestions to fix
Synchrony Pedalworks
I measured twice and even did a pilot hole, but my drilling for the Electrovibe does not perfectly match up with the faceplate. The difference is enough to make use of the faceplate difficult and risks breaking the plate.
I do not have any files to increase the whole size, but was thinking of enlarging the holes that are out of position with my step drill bit. My thought is the enlarged hole would allow some wiggle room and the nuts of the pot and switch can be anchored in the faceplate. Does this sound like a good idea or are there other suggestions? Thanks.
Reactions: fig
Just enlarge the holes in the enclosure and let the faceplate cover what you boogered up.
I have been looking at this pedal today. Would it make sense to use the faceplate as a drill template?
I would mark the circle's around all the Faceplate Holes to the Enclosure & drill separately!
Use a 2mm drill bit to drill a Pilot hole in the middle of each circle & work your way up to finish size drill bit!
The idea is if your slightly of you can steer the drill an an angle to correct misalignment!!!
