SOLVED Electrovibe No Bypass Signal, Everything Works When Effect is On
thepoofyninja
Hello everyone, I am having an issue with my Electrovibe build. When the effect is clicked on, everything works and the effect functions as it should. However, no bypass signal at all. From some other posts, I suspect its either the footswitch itself, or a bad breakout board. Does anyone know if the stock PedalPCB 3PDT breakout board will replace the Vibe Breakout board provided with the PCB? I have some extras and was thinking about replacing both the switch and the breakout board at the same time.
Sorry for no response, I was working on replacing the footswitch. It was either a faulty footswitch or I applied to much heat when attaching the breakout board. I found out the the "Vibe" breakout board is the same one as the stock 3PDT breakout boards. This pedal was not my best work :ROFLMAO:. I ended up burning a trace off the board when desoldering the footswitch so I had to run a jumper wire to a resistor leg. Then I think the LED bezel was shorting out the Intensity and Volume pots when I tightened them all the way down. Easy fix was to loosen the nuts a little. It works now but feels like its being held together with electrical tape :ROFLMAO:
