Electrovibe not vibing
ThisIsAlec
Hi all,
I just finished my electrovibe build and the thing isn’t vibing. I get a slight drop in volume when the vibrato is engaged and minor tone change when the chorus is engaged otherwise it sounds like it’s bypassing. Any ideas?
Thanks!
Hi Micmac,
The lamp is flashing nice and bright, but only when the gain is turned clockwise about 3/4 of the way. If I turn it any counter clockwise it stops flashing altogether.
And yes, I tried it with the lid on with no change. The LDRs are doing their job - I tested with an audio probe and they are warbling as expected immediately after the LDR in the audio path. However, once I test past the 4.7k resistor that sits immediately after the LDR on the audio path (R31, R41 R47 and R53) the oscillation is completely gone from the signal and it sounds dry and clean. This seems to happen after each LDR, which would explain why the output signal sounds awfully similar to the input - the effect of the light and LDRs appears stripped from the audio path.
Any ideas o' brain trust?
Thanks!
-Alec
Hi Micmac,
Thanks!
-Alec
Also, checked resistor values and the pots have covers ...
Hi all,
Thanks!
At first glance, that's a lot of socketed transistors IMO. Sure makes for a bunch of possible points of failure.
Secondly, check this switch connection I've marked to make sure it's not bridged.
I've audio probed all of the socketed transistors and they're good to go. I also saw that potential bridge and fixed it up. Still same ol' situation. This has got to be something obvious, right?
Maybe the power source? I'm getting 12v not 15v at the transitors and the lamp isn't lighting up until the trimmer is turned nearly entirely CCW. I have switched out the charge pump and regulator to no avail.
Update: I had switched the 250k and 500r trimmers, which fixes the light issue. So now it’s just that the warble from the LDRs seems to get “removed” from the audio chain, even though the signal passing through the LDR definitely modulates as intended.
Hi Alec,
I have a stock Electro Vibe, no mods, which is working. If you want me to measure anything with a DMM let me know. Happy to help.
Kind regards,
Seb
P.S.: I also have an audio probe. Can try stuff out with that, too.
Hi Alec,
Kind regards,
Seb
Amazing offer, thank you! Do any of these look odd to you? (https://docs.pedalpcb.com/project/ElectroVibe-PedalPCB.pdf)
IC4 (LT1054):
- pin 1 - 8.8v
- pin 2 - 4.8v
- pin 3 - 0
- pin 4 - 0
- pin 5 - 200mv
- pin 6 - 2.5v
- pin 7 - 1.4v
- pin 8 - 1.35v
IC1 (L78L12)
- pin 1: 16.2v
- pin 3: 12.1v
Q1:
- pin 1: 0 to 7.5v (oscillates)
- pin 3: 16.5v
Q2
- pin 1: 0 to 6.1v (oscillates)
- pin 3: 16.5v
Q3:
- pin 1: 3.1v to 3.9v (oscillates)
- pin 3: 6.2 to 9.5v (oscillates)
Q4:
- pin 1: 3.8v - 4.6v (oscillates)
- pin 2: 0 to 6.2v (oscillates)
Q5:
- pin 1: 1.25v
- pin 3: 3.4v
Q6
- pin 1: 208v
- pin 3: 9.1v
Q9, 11, 13
- pin 1: 4.2v
- pin 3: 12v
Q8, 10, 12
- pin 1: 2.8v
- pin 3: 9.2v
Hi Alec,
below mine. I added Q14 and Q15.
Please note that my LT1054 pin 1 is lifted (because my PCB has pin 1 and 8 shorted; not that I needed to lift the leg, was just a bit superstitious I guess ;)).
Measurements taken on Speed 1 (Speed 1 LED on), no input/output cable connected, all pots at 50% (12 o'clock).
Are you sure you only get 1.35V on pin 8 of the LT1054?
IC4 (LT1054):
- pin 1 - 8.8v on pcb (0.8v on lifted leg)
- pin 2 - 4.75v
- pin 3 - 0
- pin 4 - 0
- pin 5 - 200mv
- pin 6 - 2.5v
- pin 7 - 1.4v
- pin 8 - 8.84v
IC1 (L78L12)
- pin 1: 16.3v
- pin 3: 12.2v
Q1:
- pin 1: 5 to 8v (oscillates)
- pin 3: 16.7v
Q2
- pin 1: 4.7 to 7.5v (oscillates)
- pin 3: 16.7v
Q3:
- pin 1: 2.9v to 3.9v (oscillates)
- pin 3: 13.6 to 14.6v (oscillates)
Q4:
- pin 1: 3.5v - 4.6v (oscillates)
- pin 2: 13.6 to 14.6v (oscillates)
Q5:
- pin 1: 1.25v
- pin 3: 3.25v
Q6
- pin 1: 2.68v
- pin 3: 9.34v
Q9, 11, 13
- pin 1: 3.4v
- pin 3: 12.16v
Q8, 10, 12
- pin 1: 2.82v
- pin 3: 9.3v
Q14
- pin 1: 4.32v
- pin 2: 12.16v
Q15
- pin 1: 0.72v
- pin 2: 1.83v
Hi Alec,
IC4 (LT1054):
- pin 2 - 4.75v
- pin 3 - 0
- pin 4 - 0
- pin 5 - 200mv
- pin 6 - 2.5v
- pin 7 - 1.4v
- pin 8 - 8.84v
IC1 (L78L12)
- pin 1: 16.3v
- pin 3: 12.2v
Q1:
- pin 3: 16.7v
Q2
- pin 3: 16.7v
Q3:
Q4:
Q5:
- pin 1: 1.25v
- pin 3: 3.25v
Q6
- pin 1: 2.68v
- pin 3: 9.34v
Q9, 11, 13
- pin 1: 3.4v
- pin 3: 12.16v
Q8, 10, 12
- pin 1: 2.82v
- pin 3: 9.3v
Q14
- pin 1: 4.32v
- pin 2: 12.16v
Q15
- pin 1: 0.72v
- pin 2: 1.83v
This is incredible and took a ton of work, thank you! Your thinking on pin 8 was right: it was pushed in a little too far and missed the socket. The voltages on Q3 and Q4 also helped me realize I was biasing things all sorts of backwards. Between the two we have a functioning, happy electrovibe.
I cannot thank you enough! This community rocks, MicMac chief among them.
-Alec
