ENCLOSURE WATERSLIDE DECAL TUTORIAL/JOURNAL & TIPS
Thanks - I used the clear Sunnyscopa laserjet waterslide decal paper (not film-free, not white backing). I'm going to try the film-free next. To get the color on the lettering of the Paisley Drive to reproduce properly, I painted that area of the enclosure white before applying the clear decal over it so that the lettering is laying over a white backing.
Yours look great! return question: how much did the white toner cost? I've heard it can be quite expensive but haven't even seen it for sale anywhere.
Mike
For the white toner cartridge, I found one on Amazon that worked for my laser printer at around $80. I considered the Ghost White Toner as well, but didn't want to pay that much.
I have a hp m277dw, and got this:
Misee 201A CF400A White Toner Cartridge Compatible for HP Pro M252dw MFP M277dw M277 M252 M252n Printer https://a.co/d/0wM5Epr
I was thinking about also trying the waterslide laser white, but after seeing your results I may just try the clear.
Also, I am considering getting the film-free white (laminated one). There are a few pedals I want to make and they all seem to be black or really dark..
I wasn‘t real sure where to post this but this seemed like the best spot. I recently got some Koala waterslide paper off Amazon for laser printers. In the past I always used an inkjet but we no longer have one. This was my first time using the laser printer for waterslides and I was very disappointed. I am pretty certain this paper just sucks. The ink smeared on all the sheets i tried. Never seen that on a laser printer and it only did it on the waterslide paper not my test runs. I tried different printer paper settings as well just to rule it out. After i got a kinda decent (still not quality) print one got it on my enclosure. It was really difficult to get it off the backing paper and I followed there instructions to a T. Once i got it on my enclosure and got most of the wrinkles and bubbles out some of the sticker portions faded. For good measure i just let it ride and let it sit for 24 hours. I always put just a little clear top coat on the stickers after it settles and drys on the enclosure even though its not supposed to be required for laser paper. This process has always worked for me in the past. The paper was 100% dry but once the clear hit it it shriveled up and bunched in multiple spots. Needless to say I am not a fan of the Koala paper. I just wanted to give you guys a heads up in case you have thought about using it. Two thumbs down.
May be worth running through the drum cleaning procedure for your printer. On my trustly old brother, it's a process of a few buttons. Maybe will help with the smearing?
I get asked about enclosure finishing a lot in DMs from people I don't even know. So I thought to write up a tutorial/journal of waterslide decal creation and application to share for those new to waterslides for their pedals.
Waterslide decals are just one of several ways to apply artwork to an enclosure. When I started doing waterslides, I did a bit searching thru Google to see what others before me had to say on the matter. The first link I found was to this YouTube demonstration of how to do waterslides with an inkjet printer: https://www.youtube.com/watch?v=e2X_HL-4F90
There are several other such demonstrative tutorials on YouTube. A little searching there using "waterslide decals for guitar pedals" will get you more.
Note that waterslide stock comes in four (4) flavors: InkJet Clear BG, InkJet White BG, Laser Clear BG and Laser White BG
There is no white ink. Period. At least not for inkjet printers and other consumer grade printers. There are some laser jet printers that can receive a white toner cartridge. However, those white toner cartridges are more expensive than the printer. But with white-background waterslide decals stock, one can compensate for the lack of white ink when using a dark colored enclosure; but then matching a graphic's background to the enclosure color adds an interesting challenge.
The YouTube video link above was enough for me to get started. He covers a lot of the bases and in his case uses InkScape (a graphics application) to create his artwork. Personally, I like and use Photoshop. I recommend it for newcomers to waterslide decals.
I like to do a test print or two on regular cheap plain white paper in just black ink (so as not to use up too much colored ink), then cut the plain-paper print to size, place on the enclosure, re-measure all the hardware drill points and compensate for knob sizes. Then go back to the graphics software and move any design elements accordingly. That procedure lets me pinpoint where the LED and other small bits of hardware will be on the final waterslide decal stock printout.
Once I have the enclosure drilled and fit-tested the guts (circuit board and other hardware (pots & toggles), I can then make any adjustments to the artwork before committing the more expensive waterslide stock. After ALL the artwork adjustments and test-fitting the guts, I’ll print the artwork onto the waterslide stock. When I first started with waterslides, I had an inkjet printer. I learned rather quickly that inkjet waterslide printouts need at least 24 to completely dry before clear-coating the artwork. An important point to note is that the printed artwork on the waterslide MUST be clear-coated BEFORE cutting it size. Otherwise, the clear-coat will seal the edges and the waterslide will NOT release from the backing paper when soaked. A note on clear-coating: It takes some practice and trial & error. You need enough to seal and protect the artwork, but not too thick. I always print two decals in case I screw up. And don’t use cheap rattle-can clear coat. I like to use an automotive clear-coat brand like Dupli-Color. It’s more expensive than Krylon and some other brands, but you get what you pay for.
So with the clear-coated artwork on the slide prepped and ready to apply, I use warm (not hot) water with one or two drops of Dawn dish soap. The Dawn acts as a bit of surficant to improve the adhesion of the decal to the enclosure.
View attachment 49665 I also prefer to use an actual surficant like MicroScale “Micro Sol” and/or “Micro Set”. The Micro Set is for smooth surfaces to soften & improve adhesion, and the Micro Sol is for non-smooth, rougher surfaces and softened the decal a bit more to conform to irregular surfaces. I just use a small artist paint brush to apply either of these solutions directly to the surface of the enclosure. A little really goes a long way. Don’t over do it.
After soaking the decal and applying to the enclosure surface, there are a precious few moments to move it around to the correct position. There may or may not be air bubbles. If there are don’t worry. Just have an old credit card or other bit of stiff plastic with a straight edge to gently (can’t emphasize “gently” enough here) work any bubbles or wrinkles from the center, outwards. There have been instance where I really FUBAR’d the application of the decal and had corners fold underneath. Even then, don’t worry. Just use a toothpick to unfold the folded portion and get it back in place.
With the surficant solutions I often noticed how the decal would wrinkle and/or “bubble” in places AFTER I’d already worked out all the real bubbles when first applying. This really freaked me out.
View attachment 49666 LEAVE THEM! When the decal fully dries, it will contract slightly, pulling everything down flat to the enclosure. Just let it fully dry. And if it doesn’t lay flat when fully dry, don’t sweat it. Just remove the poorly adhered decal and start over. Remember, it’s a process and takes time, patience and some trial & error. I’ve made many mistakes and ruined many decals. It’s part of the game.
As you can see in this photo, the decals settled right down, laid perfect flat and are ready for the final protective finish. View attachment 49667
Eventually, my inkjet printer died and I upgraded to a color laser jet. The benefit of a laser jet with waterslides is that there is no wait time for drying. It can be clear-coated almost immediately after coming out of the printer. Some people don’t bother with clear-coating laser jet waterslides. But I prefer to still add a couple light coats of clear before proceeding to the application stage.
Once the decal is applied and dried nicely on the enclosure, there are a few different ways to more protection to the artwork. Some people like to add several more clear-coats. Others will use a good clear epoxy to cover the artwork. In the video link above, he uses (and I like this method too) MinWax Natural (Clear) furniture paste - about a dozen thin coats. It makes a good finish and allows for fingerprints and small scratches to easily be buffed out. You can choose which process you want for final finishing.
These were all done with the MinWax finishing process: View attachment 49668 View attachment 49669 View attachment 49670
Once the enclosure drilling, artwork decal and clear covering is finished, stuff that puppy with your circuit & other hardware and test your build.
And TBH, recently, I’ve taken to having my enclosures professionally drilled and UV painted by AmplifyFun. I was using Tayda for a while, but I never got the hang of vector graphics or their strict graphics policies. So I’m not doing much with waterslides lately. So I hope this short dissertation of my personal waterslide journey/tutorial can help anyone who is looking to get started with waterslide application for their pedal enclosures.
Thanks for reading. Happy building!
Hey since you use photoshop I was hoping you could help me answer a puzzling question. Looked around online but haven’t found the solution.
I downloaded the drill template from pedal pcb to start designing my decals in photoshop. I know PS and prefer to use it but unfortunately I learned the hard way after finishing my designs that something was resizing my images and the template was no longer actual size.
I have tried downloading the PDF through chrome and Firefox, also through acrobat reader. Acrobat has an “actual size” button, I tried that. I also tried importing the image at 8.5x11 (my paper size) and tested the different crop settings in the import window (even though I don’t want it to crop, there is not “no crop” option).
I ended up having to use the AI Image Resizer experimenting with different inputs for width and height. It took me hours and was different for each image. That’s not a good process and I hope to never have to do it again. So how did you do it successfully? Any issues along the way? I don’t want to download a different software.
Not to butt in, but you might want to look at the advanced printer options when the print window opens. The "fit to page" button may be selected. If it is, then click it again to turn that off. You might also look at scaling in the printer options, it may have been set forever ago and is still set at a percentage other than 100%. I don't do photoshop but I'm a retired programmer and have been using computers BEFORE windows was written. Bought my first computer in 1986 or 7.
It's actually far simpler than all that. Just work with at least 300 DPI resolution in your Photoshop files - be sure to have Rulers turned on. And ALWAYS print the results at 100%. Never "Fit to Size".
Ok, so I tried the film-free waterslide decals, but the results I got out of my laser printer were less than satisfactory. The image gets ghosted as the roller goes through its second pass, and it left me with something unusable. Any suggestions?
quick question before I try my first waterslides, do the enclosures need some prepping?
cleaning, sanding, something like that? or is it worse?
Bare, unpainted enclosures should have some light sanding done. And in all cases, an enclosure should be cleaned before water sliding. I prefer to wash them with a degreasing soap like Dawn.
Remember, there is no white ink. Whatever is white in your printable artwork will simply be the color of the enclosure.
Thanks!
I'll give it my first try this weekend
sorry, just to clarify here, how does everyone prep their bare aluminum enclosures? im planning on using this as my design (below), on white Sunnyscopa laser paper. im hoping this method works:
  1. Prepare Graphics: Download a drilling template and customize the artwork
  2. Print Drilling Template: Print the template on standard photo paper without scaling, verify the size, and cut it out
  3. Print Decal: Print your final artwork onto inkjet waterslide transfer paper (ensure you match the paper type to your printer) and let it dry
  4. Varnish Decal: Apply a coat of clear lacquer varnish over the printed decal in a well-ventilated area and let it dry
  5. Drill Enclosure: Attach the drilling template to the enclosure, mark the hole locations with a hammer and nail, and drill the holes
  6. Apply Decal: Cut out the design, immerse it in water until the decal separates from the backing, slide it onto the enclosure, and position it carefully
  7. FINISHING/FINAL VARNISH COAT: Dab away excess moisture, allow the decal to cure for 1–2 days, trim the holes with a hobby knife, and finish with multiple coats of clear varnish
    *USE "HEAVY PAPER" print mode in BROTHER PRINT SETTINGS when printing
WRESCTIFIER - TRANSFORM WATERSLIDE DESIGN 7-23-26.png 1784828240689.png 1784828255832.png
but i dont see much about preparing the enclosure. So do i just scuff it up with a lower grit (250ish) sandpaper then clean with acetone and transfer? or do i have to sand fine/wet sand, polish, do a primer style pre-clear coat in the enclosure, then transfer the waterslide decal to that?
Does everyone here sand the enclosure before transferring the decal? i think most people use pre-painted pedals. but for those of you that use bare aluminum, what do you do specifically in order to prep the surface for the waterslide transfer?
