iamjackslackof
https://www.science.org/content/article/vulnerable-transistors-threaten-upend-europa-clipper-mission
They probably all came in little pink baggies...Does this make me kinda sorta an astronaut now?!
As long as you can find Uranus, then sure!https://www.science.org/content/article/vulnerable-transistors-threaten-upend-europa-clipper-missionThey probably all came in little pink baggies...
I may not be an astronaut, but clearly I'm NASA engineer material!"NASA engineers encountered a technical constraint that precluded the adjustment of the Junction Field-Effect Transistor (JFET) bias to the target voltage of 4.5V."
