Fender Blender - Volume bypass switch
Paul1985
I want to try and mod my blender fuzz that I built a little while ago. the goal is to create a volume bypass that when engaged it sets the volume to max. Kind of have a rhythm volume then a lead volume. II believe the steps required are
Wiring Steps:​
  1. Circuit Output to Switch:
    • Connect the circuit output to the top left terminal on the DPDT switch.
  2. Volume Pot Wiper to Switch:
    • Connect the middle lug (wiper) of the volume pot to the middle left terminal on the switch.
  3. Switch to Output Jack:
    • Connect the output jack to the bottom left terminal of the switch.
  4. Bypass Connection:
    • Create a direct connection between the top right terminal and bottom right terminal on the switch to bypass the volume pot entirely when switched.
  5. Ground Connections:
    Ensure the volume pot ground remains connected to the circuit ground as it does not change during bypass.
My question is should i remove the circuit output from the main switch just to the new switch. And would i just run a patch wire from the wiper lug to the switch.
