Locrian99
Google is hard.
Google is hard.
Any thoughts/experience on/with the Laser Pecker units?It’s worth it if you’re interested in lasering other stuff too, I use it for wood projects and guitars. I started with a Pergear S10 (10w) and it worked OK and got the job done, as long as I wasn’t engraving Sand Textured enclosures from Tayda, so I upgraded this year to Atomstack S20 Pro (20w) and it works amazing, I couldn’t be happier, especially getting it for 500$ on eBay
No experience, my thoughts are the price point is pretty high for a small engraving area, for less you can get a larger area and when it comes to power it looks like their L4 is only 10w, you could get a Atomstack s20 that's 20w for 500$ brand new with air assist, and have larger space and more power. I got my S20 Pro for 500$ and LOVE ITAny thoughts/experience on/with the Laser Pecker units?
I’ve been making laser engraved faceplates which turn out nice (and I’m getting better at them). Check out my build reports.Thank you. I've been using waterslides for almost all of my builds. I recently tried Avery 4397 Glossy Sticker Project Paper, which at first seemed to be ok, but way too many bubbles in the finish -- for the record, I do not recommend this for powered coated enclosures. I've watched a lot of videos about etching, but that seems a little caustic for me. Lately, I'm interested in laser etching -- anybody had any success with that?
You are right about the fumes, I have a comgrow enclosure that vents the air out my window and it works great! And as far as alignment, I use light burn, measure an enclosure and make a square and laser the square into my fixed cardboard base I taped to my table. Works flawlessly and if I’m doing multiple 1590bb enclosures, the laser stays in the same spot so all I have to do is line the enclosure up with the square and push goI’ve been making laser engraved faceplates which turn out nice (and I’m getting better at them). Check out my build reports.
I have considered engraving the enclosure directly but I’m not sure it’s safe to do so for painted enclosures (some materials can produce toxic fumes and I’m not equipped for that). Next there is the problem of alignment which I’m not sure how to solve (but haven’t given it a lot of thought tbh).
I am gonna have to try that. But I am definitely not allowed to laser a painted enclosure (we have an Epilog Mini 24 at work that I get to use) so it'll have to be bare aluminum.You are right about the fumes, I have a comgrow enclosure that vents the air out my window and it works great! And as far as alignment, I use light burn, measure an enclosure and make a square and laser the square into my fixed cardboard base I taped to my table. Works flawlessly and if I’m doing multiple 1590bb enclosures, the laser stays in the same spot so all I have to do is line the enclosure up with the square and push go
So the only reason my diode laser woks is because it removes the paint and leaves the bare aluminum exposed beneath. A diode laser cannot engrave aluminum, but can engrave steel for whatever reason. A Co2 laser might be able to do aluminum if the power is high enough, I’m guessing 40-50w outputI am gonna have to try that. But I am definitely not allowed to laser a painted enclosure (we have an Epilog Mini 24 at work that I get to use) so it'll have to be bare aluminum.
Yeah the one I have access to is a 40W CO2 laser.So the only reason my diode laser woks is because it removes the paint and leaves the bare aluminum exposed beneath. A diode laser cannot engrave aluminum, but can engrave steel for whatever reason. A Co2 laser might be able to do aluminum if the power is high enough, I’m guessing 40-50w output
Sweet! Let me know if it works! I’ve got plans to build a co2, just not sure it’s worth it for my needs at this pointYeah the one I have access to is a 40W CO2 laser.
