Frequency central, Stasis Leak : noisy tap tempo issue.
eh là bas ma
Hello,
I finished this build recently, everything is fine, all three effects are great.
I struggled with the tap tempo on my build.
It is still noisy despite the extra wire from the switch ground going to to the enclosure, picture 2. (I thought i had seen that somewhere...and I tried.)
I also changed the red led for a yellow one for the tap tempo indicator, but it didn't change the presence of a pulsating noise.
It disappears when tap tempo is off.
The momentary switch itself is audible when i am tapping a tempo.
Any suggestions would be welcome !
I am sorry, you mean to keep the wires apart from each other inside the enclosure's space , not unsoldering anything ?
Edit : Well, i tried with unfortunatly no change. But thanks !
I also changed the tap-tempo resistor to 4k7. There is a real difference with a faint led light and a smaller noise. Still there though...
