Chuck D. Bones
Circuit Wizard
Please & thank you.
I'm getting ready to build this puppy (with a few mods, of course) and while I have VFE's schematic, I really need the schematic for this layout and a circuit card assembly diagram with ref designators on it. Saves me the trouble of reverse-engineering the board with a continuity meter.
The main part I'm fiddling is the diode clipping network. Two of the diodes will be LEDs, adding a pot and moving the DIP switch to the front panel. Also had to recalc the component values in the Mid Boost stage since I subbed a C100K dual for the unobtainable C10K dual. If it all works out, I'll publish the mods here.
